On SCOM, i monitoring Process State and now i want creat dashboard on SquaredUP show process state. What is paremeter on SquaredUP i can get state process i monitoring. Thanks
Thanks for you answer. I am building a dardboash to display process monitoring, but I cannot show the perfomance of the processes, I can only choose to display CPU or RAM, I don’t know how to display both CPU and RAM that Process is using. use
Hi, In that case, go for the Matrix tile. You can add multiple performance counters in the same dashboard for all your individual processes. Here’s some documentation:
https://support.squaredup.com/hc/en-us/articles/360007917598-How-to-use-the-Matrix-tile
