Hi I'd like to create a dashboard that shows all Active Health Service Heartbeat Failures.
I have made a simple dashboard that shows all active alerts in Critical/ error for a particular group “All Windows Computers” but want to be able to show only with Health Service Heartbeat Failure.
Specifically, look at the section “Alert Properties” and the use of “Name” – there are examples further down the page also.
One thing you will find is that scoping alerts is different from scoping objects, and the group you have specified may not contain the correct objects for Health Service Heartbeat failures, as the monitor that generates these alerts targets a different class. Removing the group and using Name in the criteria will achieve the correct results.
