I do not see all of the label counters in Squaredup that I see in SCOM. How can I see them
Please can you elaborate and update your questions with some screenshots? Presumably, this is the properties that you can see against an object? Likely, the answer is that you are not looking at an object of the correct class, for which the properties are discovered.
