Is this possible? Is it necessary to create a stub web site first and then subsequently install, and select from the drop-down for which site to install it to?
Just looking for guidance regarding the “right way” to do this for SquaredUp v3.
When you install Squared Up you can select 'modify' to choose a different Virtual Directory or Web Site. From there select the 'Paths' tab and enter the Web Site and Virtual Directory that you want - Squared Up will automatically create them if they don't already exist. The 'Layout' tab will also let you install it at the root of a Web Site if you prefer.
