Installation and License - Test\Dev\Lab
Quick question regarding the Enterprise Starter Pack, is it possible to install and run two separate SquaredUp installments on the same IIS? And use the Test & Dev license for my SCOM Lab?
You can run two deployments on the same machine, provided they have separate install locations and paths (…/squaredupv4 and …/squptest for example)
License overview: https://support.squaredup.com/v4/Reference/AnOverviewOfSquaredUpLicensing
During deployment, you are asked which management server to connect to, and you can point them at different management servers/groups
Okay, thanks Jelly - love the name btw. =)
