I’ve added a data on demand task to the Network perspective to run ipconfig. If I create this on a 2012 server then it works, but doesn’t run when looking at a 2016 server. If I edit the perspective on a 2016 server then it works, but not on 2012! Ideally, I’d like one Network perspective that would run ipconfig regardless of OS; or do I have to create OS specific perspectives? I’ve got version 1.2.4.36 of the DoD management pack.
This it the error I get when it tries to run the DoD task. Any ideas?
System.InvalidOperationException: The task cannot be executed against the object(s) because the target of the task does not match any of the classes of the object. at Microsoft.EnterpriseManagement.Runtime.TaskRuntimeManagement.ValidateTaskTargetsInternal[T](IEnumerable`1 targets, ManagementPackTask task, EnterpriseManagementGroup enterpriseManagementGroup) at Microsoft.EnterpriseManagement.Runtime.TaskRuntimeManagement.SubmitTask(EnterpriseManagementObject instance, ManagementPackTask task, TaskConfiguration configuration, TaskStatusChangeCallback callback) at SquaredUp.Connector.ScomTask.ScomTaskController.ExecuteTask(ManagementGroup mg, EnterpriseManagementObject target, ManagementPackTask task, TaskConfiguration taskConfiguration) at SquaredUp.Connector.ScomTask.ScomTaskController.<>c__DisplayClass7_0.<Execute>b__0()
You can have the pleasure of marking your own answer as the correct one.
