Is it possible with the Solarwinds MP & SCOM to monitor IPSLA for network devices?
If so how?
Thanks
If so how?
Thanks
researched that IP-SLA monitoring such as ECHO & JITTER tests are not included in the Solarwinds MP.
Hey,
You could use http://cacti.net/ for the monitoring then possibly just use the SQL plug-in to get the data on a dashboard?
. . . might work
Cheers Leigh.
