I would like to have an overview of all the commands/keywords I can use in the JSON editor so that I can really customize my dashboard.
I don’t believe there is a json reference for every tile.
Is there something specific that you’re trying to achieve?
I would like to customize my dashboard.
So I would like to know what keyword I can use in the JSON.
For instance: there is a node “source” what kind of properties can I assign to it? Scope? Countername? Display etc. etc…
I have previously asked this question to support and it has been raised as a feature request since a schema reference does not exist. (At least externally)
