I did some data on demand scripts to pull back top 10 things using CPU and Memory and display them on a dashboard. Is there a way to do this with Linux Redhat and Squared up
For sure! Just create the task and select the Unix/Linux objects:
You’ll need to ensure you select the correct target on the one of the next screens.
I’m not a Linux guy in the slightest, but there are a few articles out there:
https://operatingquadrant.com/2012/01/30/opsmgr-2012-unixlinux-authoring-templates-shell-command/
