Is there anyway I could have a column showing the exact space that is remaining? It appears there are no alert properties for this, but I’m wondering if there is some type of work around. I’ve gotten this to work when using the celltile/bar type as shown below, but I’m hoping to get this working under the celltile/text type.
As an extension to the above from Peter. You could use the “height” and “width” display properties for the scomperf-as-sparkline celltile to then essentially hide the sparkline.
e.g.
