vole
(Veli Jokela)
1
Hi
I have following problem with “Task Result” in SquaredUp portal under “Logon Simulator Monitor”.
Task result for “View Last Logon Result”, gives error:
At the test server the folder name is “Logs” (not Log):
So there is difference somewhere in the configuration, and this is why it does not find it?
Is this bug? Where could I change this?
vole
(Veli Jokela)
2
I solved this on my own.
Open Community.Citrix.LogonSimulator.mpb with MP Author - editor. Save as XML file. Open XML file with Notepad and modify line:
Get-Content $ConfigurationPath\Log$TestName\sflauncher.log</ScriptBody>
to
Get-Content $ConfigurationPath\Logs$TestName\sflauncher.log</ScriptBody>
Import as new management pack (before this delete the original MP).
Now the task works fine.
