Maintenance Mode Dash board showing Comments
We currently have a tile dashboard showing all machines in MM which works but now looking to upgrade. We would like to be able to see Comments people put in for why a machine is in MM how long it is in MM for would be a nice to have but the reason is the current ask. Anyone done this in he current build of Squared up?
You could maybe try something like this as a SQL dashboard. You would need to add the connection to the Ops Manager Database though as by default, the connection is to the DataWarehouse.
http://www.culham.com.au/blog/what-scom-objects-are-in-maintenance-mode-sql-query/
If you don’t need the “Reason Code” then you could chop out a lot of that.
I’m also going to have a look at this as this would be useful for us.
Don’t forget to ensure the ’ character is correct if copying/pasting as they tend to paste as a different character and so the sql will fail.
Andrew
Hi Rick,
Maybe I have misunderstood what you are after, as I have just come across an earlier post on this from yourself, which was answered with the same query (https://community.squaredup.com/answers/question/maintenance-mode-dash-board/)
That query already contains the comments. Are you after something different?
Andrew
