Has anybody ever created a dashboard to show what is in maintenance mode. I was thinking that might be a good one to set up so people can know what is being worked on. Any tips on how to do this.
Hi rtbywalski, I also found that having a Maintenance mode dashboard to be of value. Here is what I did. Best of luck. Matthew
I created a Dashboard named âMaintenance Mode Historyâ with two sections âObjects in Maintenance Modeâ and âMaintenance Mode Historyâ. The first section is a Status Tile (Icons) scoped to Class âWindows Computerâ with Critera âInMaintenanceMode=1 OR HealthState=0â. The second section is a SQL Tile (grid). Connection string âData Source=[your data source];Initial Catalog=OperationsManager;Integrated Security=Trueâ. Here is my SQL query:
Use [OperationsManager] SELECT FullName as [object in maintenance], CONCAT(CONVERT(VARCHAR(24),StartTime, 113), ' UTC') As 'start time', CONCAT(CONVERT(VARCHAR(24),ScheduledEndTime, 113), ' UTC') As 'scheduled end time', dbo.MaintenanceMode.[User] as [user], Case ReasonCode When 0 then 'Other (Planned)' When 1 then 'Other (Unplanned)' When 2 then 'Hardware: Maintenance (Planned)' When 3 then 'Hardware: Maintenance (Unplanned)' When 4 then 'Hardware: Installation (Planned)' When 5 then 'Hardware: Installation (Unplanned)' When 6 then 'Operating System: Reconfiguration (Planned)' When 7 then 'Operating System: Reconfiguration (Unplanned)' When 8 then 'Application: Maintenance (Planned)' When 9 then 'Application: Maintenance (Unplanned)' When 10 then 'Application: Installation (Planned)' When 11 then 'Application: Unresponsive' When 12 then 'Application: Unstable' When 13 then 'Security issue' When 14 then 'Loss of network connectivity (Unplanned)' End as [reason for maintenance], Comments FROM BaseManagedEntity INNER JOIN MaintenanceMode ON BaseManagedEntity.BaseManagedEntityId = MaintenanceMode.BaseManagedEntityId WHERE IsInMaintenanceMode = 1 AND FullName like 'Microsoft.Windows.Computer:%'
Thanks I was getting stumped on the criteria I wish I could find a document out there that would show me what my options are there.
Nice work! Iâm borrowing this query
Hello.
This dashboard is exactly what I was looking for, but unfortunately I cannot get it to work. Whenever I try to execute the SQL query against my DB, I get a bunch of errors. I have also tried to execute it directly in the SQL Management Studio, this doesnât work either. I havenât done any modifications to the SQL query at all. Iâm on SCOM 2016.
I am getting the errors stated below - can anybody tell me what I am doing wrong?
Msg 102, Level 15, State 1, Line 3
Incorrect syntax near âââ.
Msg 102, Level 15, State 1, Line 4
Incorrect syntax near âtimeâ.
Msg 132, Level 15, State 1, Line 10
The label âHardwareâ has already been declared. Label names must be unique within a query batch or stored procedure.
Msg 132, Level 15, State 1, Line 11
Msg 132, Level 15, State 1, Line 12
Msg 132, Level 15, State 1, Line 14
The label âSystemâ has already been declared. Label names must be unique within a query batch or stored procedure.
Msg 132, Level 15, State 1, Line 16
The label âApplicationâ has already been declared. Label names must be unique within a query batch or stored procedure.
Msg 132, Level 15, State 1, Line 17
Msg 132, Level 15, State 1, Line 18
Msg 132, Level 15, State 1, Line 19
We use this method also, works great.
Kenni, you will need to copy this into a notepad and change all of the â marks. It seems copy pasting from this website modifies the quotes into another character that SQL doesnât understand
