I’m trying to recreate a SCOM dashboard in SquaredUp for TLS Compliance.
This is the SCOM version:
The column headers are the properties from SCOM listed here:
This is the dashboard JSON. The bit for dotnet works.
"title": ".Net Framework Version",
"_type": "celltile/text",
"config": {
"display": {
"contentTemplate": "{{properties.dotnet}}"
This bit to try and populate the SsL_2.0cl column doesn’t:
"title": "SSL2.0 Client Status",
"config": {
"display": {
"contentTemplate": "{{properties.ssL_2.0cl}}"
I’m taking a punt that it’s to do with the underscore or fullstop characters in the ssL_2.0cl property - how do I escape those in JavaScript?
