I am being ask my my Linux team to monitor mount points. Does anyone have any tips or suggestions for best ways to achieve this?
Are we talking about ZFS and NFS?
I use this management pack
https://gallery.technet.microsoft.com/NFS-for-Linux-a161c0ec
For scom 2012 R2
Yep, this is good. I used this is a base to write my own MP to include ZFS as well.
I believe they are NFS
SLA.zip (1.81 KB)
Then the Ervia suggested MP is the one you need
I tried using that a few months back and could not make it work.
What was the problem?
SQL-Plugin.zip (1.8 KB)
Hello
Does anyone found a solution for that? I also tried the management pack, but I was not able to discover any objects.
Thanks in advance and best regards
Marcello
