I’m trying to paste a parameter from the target but I can’t get it to work. I try to past and use the link in my script:
$Target/Property[Type=“SystemLibrary7585010!System.Entity”]/DisplayName$$Target/Property[Type=“SystemLibrary7585010!System.Entity”]/DisplayName$
without knowing much of the story of what you try to achieve…
When I create a powershell based discovery or something like that. I have the parameters section in XML where you assign a parameter alias to those things you posted there. And next in the script body I start with:
param($sourceId,$managedEntityId,$computerName)
Which are the 3 aliasses in my case I put in the parameters section.
I can try and paste something like that as well, this would be parameters section below the scriptbody xml tag.
