Is there a way to put objects in the navigation bar in v3? I have a map of our network. I added to the components section of the object and made that the first tab for the object. I would like to pin this into the navigation bar. Is there a way to do this? We had it set up this way in v2.
It sounds like you added it as a perspective and not as a dashboard. This can be confusing a bit.
As jswadley mentioned, it seems like you’ve added a perspective, not a dashboard.
Once you’ve got your dashboard, go to the Settings button and then Navigation bar. Here you’ll be able to add your newly published dashboard.
