rubenz
(Ruben Zimmermann)
September 7, 2018, 5:29am
1
Hi there,
I need support with mustaches . I went through the following document, but can’t accomplish what I like to do.
https://support.squaredup.com/v3/Reference/Tiles/CustomLabelling#how-to-use-custom-labeling-display-logical-disks-with-a-custom-label-the-mustache-helper
Could you please provide some examples for:
Condition ( if property == value ) then xxx else yyy
Condition ( if property >= value ) then xxx else yyy
Substring
Replace
other useful functions you used
Thanks in advance
Ruben
Jelly
September 7, 2018, 8:19am
2
Example if statement:
{{#if displayName.toLowerCase() == 'server1.domain.com'}} srv01 {{elseif displayName.toLowerCase() == 'server2.domain.com'}} srv02 {{elseif displayName.toLowerCase() == 'server3.domain.com'}} srv03 {{else}} {{displayName}} {{/if}}
Should just be a case of adjusting == as required, using whichever property works best.
Substrings, I always use this resource:
https://www.w3schools.com/jsref/jsref_substring.asp
Mustache is just using javascript methods against the string.
Replace:
https://www.w3schools.com/jsref/jsref_replace.asp
The Tutorials on the left include everything you could need!
Let us know how you get on
rubenz
(Ruben Zimmermann)
September 7, 2018, 9:05am
3
Got it. If I can just use plain JavaScript things become easier
thank you!
Jelly
September 7, 2018, 9:07am
4
Not a problem. Another bit of advice I can give, is that the mustache helper box can be a bit of a pain to type into, especially when using the JS methods. I find it easier to select the mustache items I will include, then drop down to the json editor to make your changes. Or just outright using your favourite text editor
From what I’m seeing there is a lot of power in this area but there is a lack of samples . One example that I don’t have yet is how to provide a trend line within a grid column.
Here are the examples that I have so far for re-use: (these were provided by SquaredUp support):
Health state by text : {{#if (value == ‘Healthy’)}} {{elseif (value == ‘Potentially Overallocated’)}} {{else}} {{/if}}
Health state by value : {{#if value < 20}}{{value}} {{elseif value >= 20 && value <=40 }}{{value}} {{elseif value > 40 }}{{value}} {{/if}}
Bar chart for values : <img alt="Embedded Image"src=“data:image/png;base64,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” width={{value*4}} height=15 /> {{value}} %
I put together a more detailed version of this content in a blog post available at: Samples for SquaredUp Custom templates or mustaches - Catapult Systems
Adam
June 15, 2021, 4:05pm
10
For those more inclined towards a JS way of doing things too… ie…
{{#if value < 20}} healthy {{elseif value >= 20 && value <=40 }} warning {{elseif value > 40 }} critical {{/if}
Becomes
{{ value < 20 ? healthy : value > 40 ? critical : warning }}
Custom labelling is super flexible, and like said above very powerful. Anywhere you see the moustache picker… go wild.
