No Perspective found for the current object
Hi All,
I am trying to drill down into IIS Web server app pool settings in a dashboard I’ve created but I’m getting a message “No Perspectives found for the current object”. Has anyone come across this message before?
There are some default perspectives available on all objects. If these are missing, then something has changed with the scoping for these. The inbuilt perspectives, such as “Monitored Entity”, “Performance” etc. shouldn’t be re-scoped, otherwise, the default experience is changed.
Your best bet is to contact support and they’ll assist you.
