When i click on Maintenance i don’t see my current version nor any new updates available on V5.
Hi Kazi,
That’s very strange as it should show the current version, even if there aren’t any updates available. In the very bottom right hand corner of the Maintenance screen, it should show the version you’re currently on :-
Could you let us know what version it shows for you ? If you’re not on the latest build (5.1.1.5518), can you go to the notification tab and check to see if you’re received any notification for later versions ?
