Does anyone know what query Matt used for the count of the incidents in the ServiceManager Integration videocast? The QuickStart has the field but I am having difficulties finding a query to populate that field.
Cheers!
Cheers!
Have you taken the scripts from here?
Dont now if the count query is there but you should be able to modify one of them to do a count instead.
https://docs.microsoft.com/en-us/sql/t-sql/functions/count-transact-sql
-- Select all incidents SELECT COUNT(*) as Total FROM IncidentDimvw as incident Where CreatedDate > DATEADD(d, -120, GETUTCDATE())
That’ll get all incidents in the SCSM Datawarehouse that are less than 120 days old. If you need to do this for a perspective (computer, app, DB etc) just attach more where clauses to limit the query down to incidents related to your particular object (if you have the SCOM <-> SCSM CI connector enabled, they’ll share the same MonitoringObjectId, which makes it pretty easy).
Thanks Vyper!! That worked like a champ!
