Thanks guys, i got the Template from Support and pasted the code over the existing and got the grid layout. I simply copied code from my existing Tiles into the new ones and i was done.
But if I want to continue adding another set of Blocks down the bottom, I would just copy and paste the relevant section from the template into the bottom of my Dashboard and continue or is there something else?
Also, would be great if SquaredUp can use the dashboard creation method used to create native dashboards in SCOM console.
All you have to do is add a small Ui pop up where you have to choose:
the Template, the Grid layout, Select the number of Cells required, Select the Layout Template.
Once done than start populating the Tiles with standard SquaredUp format.
This would be a much easier approach for the uninitiated in the world of HTML/JSON coding.
