I’ve got a monitor that looks for rogue KMS servers using PowerShell to run ‘nslookup -type=all _vlmcs._tcp’
The monitor is working as expected, but I’d like to show the results of the nslookup cmd within the Alert description. Is that possible?
I’ve tried putting entries like $Data/Context/Property[@Name=’Error’]$ within the alert description, where ‘error’ is the PropertyBag that references the nslookup in the PS script, but it just returns a numerical value for each entry that I add.
Get-KMS.PS1 script:
$ScomAPI = New-Object -comObject "MOM.ScriptAPI"
# Run nslookup to get all KMS servers
$Log = nslookup -type=all _vlmcs._tcp
$Find="*kms.domain*"
# If kms.domain is present then return state OK
if($Log -like $Find)
{ $PropertyBag.AddValue("State","Ok")}
else
# If kms.domain is not present then return error state
{$PropertyBag.AddValue("State","Error!")}
# Count the number of KMS servers, should only be one
$charCount = ([regex]::Matches($log, "svr hostname" )).count
$PropertyBag.AddValue("Count",$charcount)
# Show results in Alerting
$PropertyBag.AddValue ("Error", $Log)
# Send output to SCOM
$PropertyBag
Alert description entries I’ve tried:
$Data/Context/DataItem/Property[@Name=’Error’]$
$Data/Context/DataItem/Property[@Name=’State’]$
$Data/Context/DataItem/Property[@Name=’Count’]$
$Data/Property[@Name=’Error’]$
$Data/Property[@Name=’State’]$
As an update to the above, I’m still struggling with passing the details from PowerShell through to the Alert Description. The below PowerShell is to find disconnected users on SCOM monitored servers.
#Required section for PowerShell in SCOM
#Process quser Dos Command result text into PowerShell object
$rawUserData = & quser
$wellFormedData = ($rawUserData).Trim() -replace ‘\s{2,}’,’,’ | ConvertFrom-Csv
#If there are disconnected users, set monitor to warning state
if ($wellFormedData | Where-Object {$_.ID -ge ‘4’} )
$PropertyBag.AddValue("State","OverThreshold")
else
#if no disconnected users, then monitor is green
$PropertyBag.AddValue("State","UnderThreshold")
#attempt to pass results to alert description
$PropertyBag.AddValue("output",$wellFormedData)
$PropertyBag
The monitor works as expected, but I don’t get details in the Alert Description. My Alert Description is
$Data/Context/Property[@Name=‘output’]$
Is there anything obviously wrong with the above? I’m wondering whether there’s some deeper problem with my SCOM instance; I can’t see any errors, and the script works without all the SCOM/Property Bag stuff.
