Performance Tile / Scope / Group - Is there a way to add multiple groups?
Looking to see if there is a way to add multiple groups in the performance tile / under scope than groups.
The only way i’ve found that you can do this currently is by creating a group in scom and then adding these other groups as subgroups of it. Call that “parent” group in the tile and then use the Class field to scope it to windows servers or computers to get all the objects from the subfolders displaying in the tile.
Not sure if thats exactly what your looking for but its how we currently get around it for some dashboards.
I can see uses for doing this. If it can be done I have not seen how to do it sounds like a feature request to me.
