Hi! I am new with squaredup, would like to know, how can I integrate PowerCLI in the powershell profile? Thans.
Hi @northpaul
Have you figured out your answer? I haven’t used PowerCLI inside a SCOM workflow however, as long as the agent running the powershell script has the VMWare module installed, there’s no reason why it wouldn’t run import it and run from there. Where I expect you may have issues is with authentication with the VMWare environment. Please don’t hardcode the login information inside the script…
I would recommend you maybe post something with more details so we can help out.
