Powershell: Getting alerts with group as criteria
I’m trying to create a powershell script that sends a daily report to our techs with active alerts.
We already have groups populated with servers and other objects each tech is responsible for.
I only know basic powershell, but I’ve been looking at other script and I’m now sending a daily report to myself, containing all open alerts, and alerts closed the last 24 hours.
But I can’t figure out how to get the Get-SCOMGroup and Get-SCOMAlert cmdlets to work together so that I can list only alerts with a relationship to a certain group.
I was hoping it was as easy as doing Get-SCOMGroup tech1| Get-SCOMClassInstance | Get-SCOMAlert. But this does not catch all alerts.
Anyone done this, or know how I should go about doing it?
Tao Yang did a write up similar to this a little while ago and has his script available:
Morning Check SCOM Alerts – Automated using PowerShell Script
Hopefully, you’ll be able to grab what you need from there!
Thanks Jelly. Taos script seemed a bit complicated for me, and was pretty old, so had to rewrite some of the cmdlets.
I did not get it to work the way I wanted to, I could not get it to match all the objects in the groups to the alerts.
I found another solution over at Stefan Roths blog:
https://stefanroth.net/2013/12/03/scom-2012-get-alerts-from-scom-group-showing-alert-source-information-management-pack-object-path-monitor-rule-name-etc/
And ended up doing:
$Group = Get-SCOMGroup -DisplayName $GroupName
$classinstance = $Group.GetRelatedMonitoringObjects('Recursive')
Get-SCOMAlert -Instance $classinstance
This did the trick for me!
I have a script I use to do this and it runs every day and generates an HTML email to send to engineers for alerts 48hours open. If you get stuck let me know.
(added – I have emailed you some scripts that may help).
Hi Darren, would you mind at all sharing your script with me? Sounds great, seems like what I could use instead of reinventing the wheel :slight_smile:
