Hi Jannep
Thanks for that, I have now got the PowerShell monitoring working with your help, see below for working script. However I am struggling to get the “MessageText” section input into the Alert Description, I have added the following into Alert Description but it doesnt seem to work:
$Data/Context/Property[@Name=‘MessageText’]$
SCOM management server alerts at the same time with the below:
Failed to replace parameter while creating the alert for monitor state change.
Failing replacement: $Data/Context/Property[@Name=\'MessageText\']$
WORKING SCRIPT:
Required section for PowerShell in SCOM
Query for installed SCOM Agent
$App = Get-WmiObject win32_product | where {$_.Name -eq “Microsoft Monitoring Agent1”}
If SCOM agent not installed return Error State
If ($App -eq $null)
{ $PropertyBag.AddValue(“State”,“ERROR”)
else
If SCOM agent installed return OK state
{ $PropertyBag.AddValue(“State”,“OK”)
Send output to SCOM
$messageText = “SCOM Agent is not installed”
{ $PropertyBag.AddValue(“MessageText”,$messageText)
$PropertyBag
