Hi Community,
just wanted to share a recent finding. I started to create a Dashboard that leverages the new Powershell tile. The script should fire a SQL query via dbatools .
First I created the profile:
Second I copied the script that I tested on the SquaredUp-Server directly into the Tile and executed it. - It returned an error.:
(Access to the path ‘C:\WINDOWS\system32\config\systemprofile’ is denied)
WorkAround:
I logged on to the server and granted “network service” read access on the folder mentioned and all sub-folders. Some files could not be modified, but it worked for the important ones:
Finally it worked
PS: If you are wondering why I am not using the SQL Tile; My “SQL-Days” in the IT-training-school passed long time ago
