You’ll now find built-in dashboards nested under each Data Source. If you previously installed dashboards, they’re still in your workspace — though you may want to remove any duplicates.
Why have we made this change?
To make built-in dashboards easier to discover and keep them organised alongside the data source they relate to. This update also simplifies maintenance and ensures you always have access to the latest built-in dashboards without needing to manually install updates and handle duplicates.
Where can I find the built-in dashboards now?
Built-in dashboards are now located directly under each Data Source. Head to a Data Source and expand it to see its dashboards.
What happens to the dashboards I previously installed?
Any dashboards you installed before this change are still in your workspace. Nothing has been removed automatically.
Why do I see duplicates?
Because previously installed dashboards remain available, you may see duplicates of the new built-in dashboards. You can safely delete any duplicates if you no longer need them.
Do I need to reinstall any data sources?
No — everything is automatically updated.
Will this affect any changes I’ve made to installed dashboards?
No — any dashboards you created or customised remain exactly as they were.
