Expressions let you reference dynamic values, like the current timeframe or dashboard variable, directly within a tile. They're especially powerful when building custom integrations with the Web API data source. To make them easier to use, we've added a new { } button wherever expressions are supported.
How to use it
- Look for the
{ }button in any field that supports expressions. - Click it to browse available expressions and access the full documentation.
- Select an expression to insert it into the field.
- For example, you can use
andin a query to dynamically reference the dashboard's selected time range.
Tip: If your dashboard includes a variable, you'll see additional expressions available to insert.
