My “More” drop down has become INSAINLY long. How do I go about deleting these from the drop down?
I selected Delete from the gear icon and it removed it from all other places, but it still exists in the “More” drop down.
They open, and running 3.1.11.111
The best advice I can give: Get 3.2.1 - You can manage dashboards via Settings > Dashboard Packs and delete any and all you require. You would just need to know the names of the dashboards, and then select the Everyone dashboard pack (this is where all published dashboards are saved).
When you click on the dashboards. do they open? Or do they error? And which version of Squared Up are you running?
