Our OpsLogix Ping Management Pack randomly stopped working and the error is posted below (anyone seen this before?). So, the plan is to remove this Management Pack and re-add, however, we must remove the dependencies first.
We’ve taken care of most of them but the Management Pack that contains information related to our Distributed Applications has 100+ references for OpsLogix because we use many Distributed Apps that each refer to a OpsLogix Ping monitored device. Instead of editing out the many references, should we just delete that Management Pack altogether, re-install the Ping Management Pack, and import the backup of the Management Pack again?
We use Distributed Applications for one of our most important dashboards, so we want to ensure that we won’t lose anything by deleting out the associated Management Pack temporarily.
Here is the error we get when trying to remove devices from OpsLogix Ping Dashboard
Here is the error and I had seen another post about this with no resolution
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Ping.UI.Services.ScomService.RemoveTargetInstance(String hostName, String targetName, String targetDisplayName)
at Ping.UI.Models.HostModel.RemoveTargets(IEnumerable`1 targets)
at Ping.UI.Presenters.TargetHostPresenter._targetSourceHostView_RemoveTargetsEvent(Object sender, RemoveTargetsEventArgs e)
at Ping.UI.UserControls.TargetHostControl.removeTargetHostButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Microsoft.EnterpriseManagement.Monitoring.Console
Assembly Version: 7.0.5000.0
Win32 Version: 7.1.10226.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Monitoring.Console.exe
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Microsoft.EnterpriseManagement.Presentation.Core
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Core.DLL
Microsoft.EnterpriseManagement.UI.ConsoleFramework
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.ConsoleFramework.DLL
PresentationFramework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Xaml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
Microsoft.Practices.Prism.UnityExtensions
Win32 Version: 4.0.0.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Practices.Prism.UnityExtensions.DLL
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Practices.Prism.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.EnterpriseManagement.Monitoring.Console.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Monitoring.Console.resources.DLL
Microsoft.EnterpriseManagement.UI.Foundation
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Foundation.DLL
System.ServiceModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel/v4.0_4.0.0.0__b77a5c561934e089/System.ServiceModel.dll
SMDiagnostics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/SMDiagnostics/v4.0_4.0.0.0__b77a5c561934e089/SMDiagnostics.dll
System.ServiceModel.Internals
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ServiceModel.Internals/v4.0_4.0.0.0__31bf3856ad364e35/System.ServiceModel.Internals.dll
UIAutomationTypes
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
Microsoft.Practices.Unity
Assembly Version: 2.0.414.0
Win32 Version: 2.0.414.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Practices.Unity.DLL
Microsoft.EnterpriseManagement.Presentation.DataAccess
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.DataAccess.DLL
Microsoft.EnterpriseManagement.Presentation.Security
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Security.DLL
Microsoft.EnterpriseManagement.CompositionEngine
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.CompositionEngine.DLL
Microsoft.EnterpriseManagement.Presentation.Tuneup
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Tuneup.DLL
Microsoft.EnterpriseManagement.Monitoring.Components
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Monitoring.Components.DLL
Microsoft.EnterpriseManagement.Monitoring.DataProviders
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Monitoring.DataProviders.DLL
Microsoft.EnterpriseManagement.Management.DataProviders
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Management.DataProviders.DLL
Microsoft.EnterpriseManagement.Presentation.DataProviders.Library
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.DataProviders.Library.DLL
Microsoft.EnterpriseManagement.Presentation.Visual
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Visual.DLL
Microsoft.EnterpriseManagement.Presentation.Controls
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Controls.DLL
Microsoft.Practices.ServiceLocation
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Practices.ServiceLocation.DLL
Anonymously Hosted DynamicMethods Assembly
Assembly Version: 0.0.0.0
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
Microsoft.EnterpriseManagement.Presentation.Visual.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Presentation.Visual.resources.DLL
Microsoft.EnterpriseManagement.Presentation.Controls.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Presentation.Controls.resources.DLL
PresentationFramework.Aero2
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
System.ComponentModel.Composition
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.ComponentModel.Composition/v4.0_4.0.0.0__b77a5c561934e089/System.ComponentModel.Composition.dll
System.Runtime.Serialization
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Microsoft.EnterpriseManagement.Management.Transport
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Management.Transport.DLL
Microsoft.EnterpriseManagement.CompositionEngine.Extensibility
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.CompositionEngine.Extensibility.DLL
Microsoft.EnterpriseManagement.OperationsManager
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.EnterpriseManagement.OperationsManager/7.0.5000.0__31bf3856ad364e35/Microsoft.EnterpriseManagement.OperationsManager.dll
Microsoft.EnterpriseManagement.Core
Win32 Version: 7.5.3079.607
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.EnterpriseManagement.Core/7.0.5000.0__31bf3856ad364e35/Microsoft.EnterpriseManagement.Core.dll
Microsoft.EnterpriseManagement.UI.Console.Common
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Console.Common.DLL
Microsoft.Mom.UI.Components
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Mom.UI.Components.DLL
Microsoft.Mom.UI.Common
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Mom.UI.Common.DLL
Microsoft.Mom.Common
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Mom.Common.DLL
Microsoft.EnterpriseManagement.UI.Authoring
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Authoring.DLL
Microsoft.Mom.UI.Components.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.Mom.UI.Components.resources.DLL
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Reactive
Assembly Version: 1.0.10425.0
Win32 Version: 1.0.10425.1
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/System.Reactive.DLL
System.IdentityModel
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.IdentityModel/v4.0_4.0.0.0__b77a5c561934e089/System.IdentityModel.dll
Microsoft.EnterpriseManagement.UI.ConsoleFramework.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.UI.ConsoleFramework.resources.DLL
System.Transactions
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
Microsoft.EnterpriseManagement.UI.Administration
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Administration.DLL
Microsoft.Mom.UI.Common.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.Mom.UI.Common.resources.DLL
Microsoft.EnterpriseManagement.UI.Console.Common.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.UI.Console.Common.resources.DLL
WindowsFormsIntegration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
Microsoft.EnterpriseManagement.UI.Controls
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Controls.DLL
Microsoft.EnterpriseManagement.UI.ViewFramework
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.ViewFramework.DLL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
Microsoft.EnterpriseManagement.UI.Controls.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.UI.Controls.resources.DLL
UIAutomationProvider
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
PresentationFramework-SystemXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Microsoft.EnterpriseManagement.UI.Reporting
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.Reporting.DLL
Microsoft.Mom.Isam.Interop
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Mom.Isam.Interop.DLL
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
Microsoft.EnterpriseManagement.Core.resources
Win32 Version: 7.5.3070.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Core.resources.DLL
Microsoft.EnterpriseManagement.Runtime
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.EnterpriseManagement.Runtime/7.0.5000.0__31bf3856ad364e35/Microsoft.EnterpriseManagement.Runtime.dll
Microsoft.EnterpriseManagement.UI.WizardFramework
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.UI.WizardFramework.DLL
Microsoft.EnterpriseManagement.Monitoring.UnitComponents
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Monitoring.UnitComponents.DLL
Microsoft.EnterpriseManagement.Presentation.DataAccess.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Presentation.DataAccess.resources.DLL
Microsoft.EnterpriseManagement.UI.Reporting.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.UI.Reporting.resources.DLL
Microsoft.EnterpriseManagement.UI.Administration.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.UI.Administration.resources.DLL
PresentationFramework-SystemData
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
System.Numerics
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Microsoft.SystemCenter.Advisor.Common
Assembly Version: 7.0.5000.9
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.Presentation.Core.dll
Microsoft.SystemCenter.Advisor.UI
Microsoft.EnterpriseManagement.DiagramFx
Assembly Version: 7.1.1000.0
Win32 Version: 7.1.3840.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.EnterpriseManagement.DiagramFx.DLL
Microsoft.SystemCenter.Advisor.UI.resources
Microsoft.EnterpriseManagement.Modules.Apm.TfsWISync.Common
Interop.Shell32
Assembly Version: 7.1.10226.0
Microsoft.EnterpriseManagement.Modules.Apm.AlertAttachment.Modules
Microsoft.EnterpriseManagement.Modules.ModuleDebug
Microsoft.EnterpriseManagement.Modules.Apm.TfsWISync.ComponentTasks
Microsoft.EnterpriseManagement.HealthService
Microsoft.Mom.Modules.DataTypes
Win32 Version: 7.1.10184.0
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/Microsoft.Mom.Modules.DataTypes.DLL
WPF.OpsLogix.IMP.Base.UI
Assembly Version: 3.0.0.42
Microsoft.EnterpriseManagement.Monitoring.SyntheticTransaction.UnitComponents.Wpf
Microsoft.EnterpriseManagement.Modules.Apm.AlertAttachment.ComponentTasks
Microsoft.EnterpriseManagement.Monitoring.ServiceLevel.Components
Microsoft.Windows.Server.2016.Components.WPF
Assembly Version: 10.0.19.0
Microsoft.SystemCenter.Visualization.Component.Library.WPF
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
Microsoft.SQLServer.Visualization.Library.DataObjectContext.Wpf
Assembly Version: 7.0.7.0
System.Windows.Interactivity
Microsoft.SQLServer.Visualization.Library.Entities.Wpf
Microsoft.SQLServer.Visualization.Library.Controls.Wpf
Ping.UI
System.Xml.Linq
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
Microsoft.EnterpriseManagement.Monitoring.Components.resources
CodeBase: file:///C:/Program%20Files/System%20Center%20Operations%20Manager%202012/Console/en/Microsoft.EnterpriseManagement.Monitoring.Components.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging=“true” />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
