Resetting health on Dependency rollup monitors
We are integrating SCOM with ServiceNow and find their out of the box integration a little lacking. For example when a SN ticket is closed it simply closes the SCOM alert, not taking into account the health. We are looking to rewrite some of this integration to instead reset health on monitors. This works fine except for Dependency rollup monitors.
Anybody have PowerShell code that can take an alert and find the dependency child objects and reset them?
Would this help: https://cookdown.com/alert-sync/ ?
Two-way alert sync and from what I gather, it can reset monitors when required also.
I actually talked to them, we found this solution won’t do dependency monitors, they need to update this blog post. It works on aggregate roll-ups.
This is the post
https://cookdown.com/blog/
Ah that’s a shame :frowning:
