Guys, i am stuck in another Authoring issue. Planning for a 2016 migration i have created a management pack wich have some agent/Health service tasks to add and remove management Groups.
The problem is that I want to restart the healhtservice after i have finished management Group configuration. I have seen some VB scripts to do this in a task, but i want to do it within the same task adding or removing MG’s. Until now i have tried to realoadConfiguration within the script, calling a CMD using net-stop and net-start without any luck
The script and task does work. but fails in the console since HS is stopped
.SYNOPSIS
Easially remove management group from agent
.DESCRIPTION
Remove one connected management group from agent. Use in migration and/or test environments etc
.EXAMPLE
Remove-SCOMManagementGroup.ps1 -MGMTGroupName SCOMMG
Removes the specified MG from agent and restarts the health service.
.NOTES
Author: Martin Ehrnst /Intility AS
November 2016
Version 1.0
Param(
[Parameter(Mandatory=$True)]
[string]$MGMTGroupName
$ErrorActionPreference='Stop'
Write-Host "This will remove $MGMTGroupName from agent. All monitoring will stop."
#Getting MG and removes if exist
try{
#Logging event
$api = new-object -comObject MOM.ScriptAPI
$api.LogScriptEvent("Remove-SCOMManagementGroup.ps1", 1001, 4, "Removing agent from $MGMTGroupName Workflow initiated from OpsMgr Console")
$Agent = New-Object -ComObject AgentConfigManager.MgmtSvcCfg
$MG = $Agent.GetManagementGroup($MGMTGroupName)
if ($MG){
$Agent.RemoveManagementGroup($MGMTGroupName)}
else{
Write-Verbose "Could not find specified Management Group"}
catch{
Write-host "An error occured please se exeption message:"
Write-error $_.Exception.Message
BREAK
Write-Host "Successfully removed $MGMTGroupName"
