What do others do to ensure that every server in their environment has a SCOM agent installed? I am running SCOM 2016 and the bulk of my servers are VM so I was thinking we might add it to the template for server deployment to make sure that all new servers get the agent. I also need a way to go back and ensure all existing servers have the agent installed.
I am also finding an issue with rouge servers getting added by some of my IT groups that did not go through the server team for getting added so they are not in the right OU in AD so we do not see them in SCCM or SCOM.
So any tips for helping to audit and ensure everything is monitored
Same here. We have a small team that builds the servers. A script which is called by SCCM installs SCOM agent and another one the Antivirus Client. - I would say it’s half - automated at the moment.
The ‘assurance’ question sounds interesting actually. I have an idea and will try a little bit.
$messageText = "Failed to load data from Active Directory. RSAT installed?"
$numberUnmonitored = 1000
if($numberUnmonitored -gt 0) {
$messageText = “$($numberUnmonitored) Servers are not monitored via SCOM Agent. n" $messageText += "Details: n $($missingInScom)”
$propertyBag.AddValue(“Result”,“OverThreshold”)
} else{
$messageText = “All server in AD are monitored via SCOM Query.”
$propertyBag.AddValue(“Result”,“UnderThreshold”)
These are some really good ideas I will have to look at them. Has anybody included them in their VM Ware templates as that would be the quickest way to get it on new machines since we are 95% VMware on our machines and any physical box would be an anomaly.
Process - Process - Process! I am aware of at least one org that will not allow a machine to be built without documentation, asset management, and reg keys (used for SCOM discovery) defined beforehand. We’re a small org with only 3 guys deploying VMs - A semi-regular check of AD with PowerShell and a comparison to SCOM is the only way we get this done ourselves.
