We have been having an issue for a while (SCOM 2016 UR3, Squaredup 4.0.4) where sometimes I will get a browser login prompt in which I cannot login to. If I look at the transit log I see the following. The only way to fix this issue is to reboot the squaredup server. IISReset or App Pool Cycle does not fix the issue. I even tried restarting the Microsoft Monitoring Agent. Anyone seen this before?
System.UnauthorizedAccessException: The user does not have sufficient permission to perform the operation. —> Microsoft.EnterpriseManagement.Common.UnauthorizedAccessEnterpriseManagementException: The user does not have sufficient permission to perform the operation. —> System.ServiceModel.Security.SecurityNegotiationException: The caller was not authenticated by the service. —> System.ServiceModel.FaultException: The request for security token could not be satisfied because authentication failed.
at System.ServiceModel.Security.SecurityUtils.ThrowIfNegotiationFault(Message message, EndpointAddress target)
at System.ServiceModel.Security.SspiNegotiationTokenProvider.GetNextOutgoingMessageBody(Message incomingMessage, SspiNegotiationTokenProviderState sspiState)
— End of inner exception stack trace —
Server stack trace:
at System.ServiceModel.Security.IssuanceTokenProviderBase1.DoNegotiation(TimeSpan timeout) at System.ServiceModel.Security.SspiNegotiationTokenProvider.OnOpen(TimeSpan timeout) at System.ServiceModel.Security.WrapperSecurityCommunicationObject.OnOpen(TimeSpan timeout) at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout) at System.ServiceModel.Security.CommunicationObjectSecurityTokenProvider.Open(TimeSpan timeout) at System.ServiceModel.Security.SecurityProtocol.OnOpen(TimeSpan timeout) at System.ServiceModel.Security.WrapperSecurityCommunicationObject.OnOpen(TimeSpan timeout) at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout) at System.ServiceModel.Channels.SecurityChannelFactory1.ClientSecurityChannel1.OnOpen(TimeSpan timeout) at System.ServiceModel.Channels.CommunicationObject.Open(TimeSpan timeout) at System.ServiceModel.Channels.LayeredChannel1.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.OnOpen(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOpenOnce.System.ServiceModel.Channels.ServiceChannel.ICallOnce.Call(ServiceChannel channel, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.CallOnceManager.CallOnce(TimeSpan timeout, CallOnceManager cascade)
at System.ServiceModel.Channels.ServiceChannel.EnsureOpened(TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
