We are seeking SCOM 2012 (or higher) + Exchange 2013/2016 expertise to help fix ongoing issues with healthsets getting critical. Scope of work is configure properly the managed availability OR disable the not applicable healthset checks, and offer about two days custom training around SCOM+Exchange.
My recommendation would be "PluralSight or Lynda" for Exchange and SCOM trainings. I have made good experience with the first platform mentioned.
I can share the overrides made for Exchange 2010. I assume the rules & monitor names did not change much. You could check the names of the monitors and rules in the screenshot and see if they match. - In case they do I will place the text here plus the Powershell you need to set them.
