SCOM Group doesnt appear anymore in Groups
I had created groups to be dynamically populated with members.
once i finished, i then wanted to create a Rollup Health State monitor on the group using the task configure HealthRollup.
after that i cant see the groups anymore in the Groups in Authoring , and if i want to modify the rule of populated members or do any changes on the Group i cant do that.
can some please help?
Thanks
this is a known issue with groups if you have used one to add to a DA. Check this post out to resolve it.
https://blogs.technet.microsoft.com/momteam/2015/05/12/where-on-earth-did-that-group-go-why-opsmgr-groups-may-go-missing-when-added-to-a-distributed-application/
In essence you create a top level group which has all the other groups as members.
Hi Aatefsoliman,
This is very strange, the group should not disappear just because you have created the rollup monitor.
Can you still see the management pack you saved the group into via the Administration workspace > Management Packs?
Hi Jelly,
yes i can see the management pack, and i can see them also in discovered inventory, but i cant see them in the groups panel, as therefore i cant really do anything with them or edit them.
