I have created a sealed Management Pack that will extend the Windows Computer object by adding an additional Attribute called “Support Level” - This value is populated in the Registry based on values stored in SQL then the agent writes the value into SCOMDB. I have then created a SCOM Group that will dynamically populate based on the “Support Level” value
I followed Kevin Holmans Post below:-
The above works really well, however, let’s say I want to add Explicit Members to the group I won’t be able to as the Group is in a Sealed Management Pack.
Is there a way to provide the functionality for Explicit Members to be added via an override?
