I need to refer to the sealed version of OMS management packs but not sure where I can find them. Can anyone help?
have you checked here? http://systemcentercore.com
Sealed OMS management packs can be found in C:\Windows\Temp folder on your SCOM server. Stefan Roth’s blog post goes into more detail:
https://stefanroth.net/2016/12/01/oms-where-can-i-find-the-sealed-oms-mps-intelligence-packs/
