saars
(Liam Matthews)
February 12, 2018, 10:55pm
1
I currently have dashboards that pull data from the SCCM SQL server for deployment compliance
Staring at a table is not that great for management so I was hoping to be able to use SLA monitoring, I’m just not sure how to go about it
Can anyone point me in the right direction, I know something will need to be set up in SCOM, I just can’t think of what
rubenz
(Ruben Zimmermann)
February 13, 2018, 1:31am
2
I’d use PowerBI for it. - Power BI desktop is a free Microsoft tool which can do data-transformation and visualization.
There are some pretty templates which can help you to retrieve and present data form SCCM aleady.
Take a look and let me know what you think:
https://powerbi.microsoft.com/en-us/blog/sccm-solution-template/
http://www.scconfigmgr.com/2017/11/07/patch-compliance-reporting-in-configuration-manager-with-powerbi/
rubenz
(Ruben Zimmermann)
February 13, 2018, 4:42am
3
Understood. - Perhaps there is a way to accomplish it with SquaredUp.
… I’m unfortunately just using SquaredUp’s free software, not their flag-ship
Jelly
February 14, 2018, 10:17am
4
You should be able to embed the PowerBI dashboard into SQUP using the HTML tile. I haven’t tested this though… That way, as far as the desk is concerned, they are just looking at a “prettified” data dashboard within SQUP.
saars
(Liam Matthews)
February 13, 2018, 3:54am
5
I was hoping to keep it all in the same tools. Our Ops bridge use SquaredUp and I don’t want to introduce something new
