smart card for login to squaredup
Is it possible to use a smart card for login to squaredup? If I’m using Active Directory Certificate Services to issue smart card certificate to my users, can they use smart card to login to squaredup?
Hi Miguel,
I believe that should be possible somehow as SU uses IIS. - I would firstly try it with a sample website.
https://docs.microsoft.com/en-us/archive/blogs/asiatech/how-to-create-an-iis-website-that-requires-client-certificate-using-self-signed-certificates
https://medium.com/@hafizmohammedg/configuring-client-certificates-on-iis-95aef4174ddb
https://medium.com/@yildirimabdrhm/configuring-iis-for-client-certificate-mapping-authentication-d7f707506a97
Does that help?
Ruben
I will follow this. I´m also looking at this. We are using yubikey and certs for MFA. I have not been able to get the Squaredupweb to show the smartcard as a login alternative.
