Has anyone had the following happen to them? I create an SQL Dashboard and put in a query. I get no output and the query disappears from the dashboard settings.
The query is visible until you hit Done
Scalar Unit Labels appear in the Dashboard but no query data
It happens with the basic sample query number of active alerts query from the SQL Config info.
