Is there a way to turn off the SquaredUp menu? There use to be a url switch that removes the menu
Appending
?display=fullscreen
At the end of an menu on Version 3 still works for me. (just tried and confirmed it)
It works for both full and open access.
Yes, that is the one! Thank you
That’s just revealed a fun bug. If you then go back a page, the navigation is removed still…
Had to close my browser to bring navigation back. In Open Access this is fine!
I just removed “?display=fullscreen” and the navigation reappeared.
I just tried it again, and it worked fine.
This was in the full version (logged in).
I’ve done the same but it doesn’t come back. I’ve logged it with support now, figured they would want to know
