Textbox Variable for Powershell tile
Using SquaredUp V5 and can create a tile that runs a powerhell script and shows the results. However I wonder if it is possible for a tile to have a textbox for a user to enter a value and that value is used within a script to generate the data?
Or would this need to be a feature request for future versions?
Sounds like a great feature request!
Hey Mad,
Please can you reach out to Support with this to be raised as a feature request?
Thanks!
