Tile with different monitors
Is it possible to have a tile with different monitors in it … such as temperature sensors … temp sensor from a UPS - temp from an IO Box located in a cabinet (discovered via SNMP?)?
thanks.
You’re able to display monitors in Squared Up using the monitors tile. You can show multiple monitors, but they will need to be targeted at the same object/group etc. If your monitors are targeted at different objects then you’ll need multiple tiles.
