After upgrading from V4 to V5 using side by side V4 will still be available to use right ? Just incase if anything happens to the upgrade.
Welcome to the community kazi!
Absolutely!
Side-by-side gives you a chance to see what the upgrade will look like, as it copies your existing content and configuration.
Few points:
- API providers will need to be recreated
- Side-by-side is only available for the SCOM product
Full docs available here:
SCOM: How to migrate from SquaredUp for SCOM v4 to v5 – SquaredUp Support
Azure: How to migrate from SquaredUp for Azure v4 to v5 – SquaredUp Support
Thank you so much Jelly,
Is there any documentation also for migrating Squaredup into a new server ? In our environment we have V4 and we want to upgrade it to V5. Also we might end up putting Squaredup into a new server.
This is a bit trickier.
You should only ever migrate SquaredUp content between servers on the same version.
With this in mind, I would recommend performing a side-by-side upgrade to v5 on your existing server, then install the same version on your new server, and following the Backup and Restore documentation below:
With the restore step you simply restore the content to your new server.
As this is a little more involved, you can always contact support for assistance.
Thank you so much for the support.
Not a problem
If you would be so kind, please mark one of the responses as Solving the problem - This will let other users more easily find a solution if they have the same question. You can do this by click the elipsis next to Reply and checking the Solution box:
