I just installed SquaredUp and want to use VADA to figure out all the applications that are using a file and print server as a File Share. Can VADA do this?
In short, yes. VADA will display TCP/IP connections from monitored endpoints to monitored/unmonitored endpoints.
Long answer: VADA is on demand - You would need to run the discovery whilst the connection is open. If the application only connects once an hour, you will likely have trouble discovering at the right time. You can, however, add in dependencies manually - But the question is posed in a “we do not know what applications are using this file share” which will make the task somewhat more complicated
