Have you also imported the management pack that contains the DA into SCSM?
A caveat of having this MP go into SCSM is that it only contains objects already in SCSM. If you’ve edited the DA in SCOM and added a network device or other objects that aren’t already in SCSM, then the DA will not appear.
Have you also imported the MP generated by VADA containing your application into SCSM, and then configured the SCOM CI connector to sync objects from that MP?
You may find if your DA contained objects that were not being synced into SCSM (such as network devices) you’ll need to import other MPs into SCSM first that define those objects. The SCSM MP import wizard will generate the errors for you and tell you which MPs you are missing, but be warned it’s no where near as user-friendly and intuitive as the SCOM console’s.
Hi Jelly - See my screenshots.
You were right - the MP were located in C:\Program Files\Microsoft System Center 2012\Service Manager\Operations Manager 2012 R2 Management Packs. However when I tried to import the one causing the problem it says that it is already imported?
“I almost thought we had it sorted”
Based on the screenshot, you are trying to import the wrong MP. You need Microsoft.Windows,Image.Library, not System.Image.Library. If that MP isn’t available with the SCSM binaries, you can find it on the SCOM installation media (there is a Management Packs folder, should be in there).
Am I right in thinking that the service components should now contain the objects defined in the DA? See my screenshot - For some reason mine doesn’t expand to show the associated components?
Am I right in thinking that the service components should now contain the objects defined in the DA? See my screenshot – For some reason mine doesn’t expand to show the associated components?
