Vada discovery in SCOM with multiple Management Groups
Has any research been done on Vada discovery in SCOM with multiple Management Groups
At the present time, Squared Up as a whole (and, thus VADA in particular) only talks to one management group at any time; I am unaware of any plans to change this.
If you have an application that spans infrastructure monitored by different MGs, you will have to discover your application topology separately on each.
Regards.
This is why I’m looking into a shared DataWarehouse configuration.
I’m not sure this would solve the VADA issue, as the objects would be monitored in two separate environments. I’m not sure the Agent task would work in the same way?
